January 27, 2021 at 6:30 pm
mcpattydaddy
SubscriberHello, I've been trying to incorporate a mesh into a elbow pipe in Ansys fluent. I'll create the geometry and generate the shape, but when I click on mesh it says an error occurred and that it's in C:\Users\david\AppData\Local\Temp\AnsysWBDumpFile.dmp . I've read the other forums that solve this issue for other people, but non of them have worked for me. I changed the nvidia to higher graphics, I added the dll's, I tried to redownload it, and I've redone the geometry dozens of times.nnAny tips on how to help? I'd really like to figure this out so I don't have to run it through citrix...n -
February 2, 2021 at 7:13 pm
ANSYS_MMadore
Forum ModeratorArray Have you tried renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old where vXXX is the version you're running? Does this only happen with that one project?n -
February 2, 2021 at 9:52 pm
mcpattydaddy
Subscriber@mcpattydaddy Have you tried renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old where vXXX is the version you're running? Does this only happen with that one project?/forum/discussion/comment/105375#Comment_105375
I did try that, and it still popped up with the same error. I've also tried different projects and the same message pops up, some in fluent and others in static structural. n -
February 10, 2021 at 8:41 pm
mcpattydaddy
SubscriberI have the dump file copied to my desktop, it won't allow me to place it here. It's encrypted, but I can send it to someone on the support team to see what it says and maybe that will provide an answer to why it's giving me such problems.n -
February 10, 2021 at 8:48 pm
ANSYS_MMadore
Forum ModeratorPlease open a Windows command prompt and run the command set and return the full output.nn -
February 10, 2021 at 10:00 pm
mcpattydaddy
SubscriberC:\Users\david>setnADSK_CLM_WPAD_PROXY_CHECK=FALSEnALLUSERSPROFILE=C:\ProgramDatanANSYS211_DIR=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\ANSYSnANSYS_SYSDIR=winx64nAPPDATA=C:\Users\david\AppData\RoamingnAWP_LOCALE211=en-usnAWP_ROOT211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211nCADOE_LIBDIR211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\CommonFiles\Language\en-usnCommonProgramFiles=C:\Program Files\Common FilesnCommonProgramFiles(x86)=C:\Program Files (x86)\Common FilesnCommonProgramW6432=C:\Program Files\Common FilesnCOMPUTERNAME=DESKTOP-LRHAV4FnComSpec=C:\WINDOWS\system32\cmd.exenDriverData=C:\Windows\System32\Drivers\DriverDatanHOMEDRIVE=C:nHOMEPATH=\Users\davidnLOCALAPPDATA=C:\Users\david\AppData\LocalnLOGONSERVER=\\DESKTOP-LRHAV4FnLSTC_LICENSE=ANSYSnNUMBER_OF_PROCESSORS=8nOMP_NUM_THREADS=8nOneDrive=C:\Users\david\OneDrivenOneDriveConsumer=C:\Users\david\OneDrivenOS=Windows_NTnPath=C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\Program Files\MATLAB\bin;C:\Users\david\AppData\Local\Microsoft\WindowsApps;nPATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSCnPROCESSOR_ARCHITECTURE=AMD64nPROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntelnPROCESSOR_LEVEL=6nPROCESSOR_REVISION=9e09nProgramData=C:\ProgramDatanProgramFiles=C:\Program FilesnProgramFiles(x86)=C:\Program Files (x86)nProgramW6432=C:\Program FilesnPROMPT=$P$GnPSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\ModulesnPUBLIC=C:\Users\PublicnSESSIONNAME=ConsolenSystemDrive=C:nSystemRoot=C:\WINDOWSnTEMP=C:\Users\david\AppData\Local\TempnTMP=C:\Users\david\AppData\Local\TempnUSERDOMAIN=DESKTOP-LRHAV4FnUSERDOMAIN_ROAMINGPROFILE=DESKTOP-LRHAV4FnUSERNAME=davidnUSERPROFILE=C:\Users\davidnwindir=C:\WINDOWSn -
February 14, 2021 at 5:44 pm
ANSYS_MMadore
Forum ModeratorPlease run dxdiag from a Windows command prompt and send the full output.n
Viewing 6 reply threads
- The topic ‘How can I fix ” C:UsersdavidAppDataLocalTempAnsysWBDumpFile.dmp “?’ is closed to new replies.
Ansys Innovation Space
1333
1168
1090
1014
