January 19, 2021 at 3:59 am
Sherin
SubscriberHello,
While using Ansys Maxwell, I tried to Run Script.Â
But there is an error message appeared.
The image is attached for your reference.
January 21, 2021 at 12:55 pmrtk
Ansys Employee,nThis error usually appears due to some of the below causes:nAnsys tool installed on a server and you are trying to run the script from the client machine.nMissing Library... can consider re-installing the Ansys tool and check. (Uninstall completely and then install through proper channel)nDue to permission problemsnHope this info can sort out the issue. Please let me know if you have any further questions.nnBest Regards,nViewing 1 reply thread- The topic ‘SCRIPT RUNNING ERROR’ is closed to new replies.
