January 18, 2021 at 10:12 pm
Conner_sabin
SubscriberJanuary 18, 2021 at 10:25 pmJanuary 19, 2021 at 7:56 amPraneeth
Ansys EmployeenPlease make sure you select at least one object in your geometry when trying to plot any fields.nAll the best.nBest Regards,nJanuary 19, 2021 at 7:13 pmJanuary 20, 2021 at 8:11 amPraneeth
Ansys EmployeenPlease share the profile data screen shots of the solution setup to help us serve you better.nBest Regards,nJanuary 21, 2021 at 5:04 amConner_sabin
ArrayHere are screenshots of my Solution Type and Solution setup. As I am looking at it, I am realizing that I might know what the problem is. I think my problem is the Saved Fields solution setup. In order to simulate the electric fields on any object, do I need to add that object to the list and enable the saving of fields? n
n
January 21, 2021 at 6:56 amPraneeth
Ansys EmployeeHiArray,nPlease create a object or face list to enable the save fields option for Transient analysis. Go through Creating an object list section in the HFSS Help PDF document for detailed information. You can also go through Adding a Solution Setup for Transient Solutions section for more details from the same HFSS help document.nAll the very best.nBest Regards,nViewing 6 reply threads- The topic ‘Why does it not allow me to plot the E Field in HFSS?’ is closed to new replies.
5074
1797
1387
1248
