How to find the frequency response of the simulated structure.
    • Simon1998
      nYou are showing a Static Structural analysis. You pasted in an image of a YouTube video that shows a Modal analysis. Neither has what you want.nYou need to drag and drop a Modal analysis on the Model cell of your Structural analysis in Workbench. Then in Mechanical, drag and drop the Fixed Support from Static Structural to Modal.nNext you need to drag and drop a Harmonic Response analysis onto the Solution cell of the Modal analysis in Workbench. Then in Mechanical, drag and drop the Nodal Force onto the Harmonic Response.nYou might find these videos helpful. n/forum/discussion/687/bridge-building-in-spaceclaim-with-modal-and-harmonic-response-analysisn
  • The topic ‘How to find the frequency response of the simulated structure.’ is closed to new replies.
