January 13, 2021 at 1:52 pm
Emmanuel001
SubscriberGood day all,
I am working on thermal analysis of a motor in
January 13, 2021 at 3:44 pmRahul Kumbhar
Ansys EmployeeCould it be export setting issue on Maxwell side. Please check this post.n/forum/discussion/22915/negative-loss-imported-into-steady-state-thermal#latestnJanuary 13, 2021 at 8:08 pmEmmanuel001
SubscriberThank you Sir for the quick suggestion. I have gone through the discussions in that link but I am still confused. I don't know how to effect the motion setup and analysis settings so that the problem will be solved as suggested in the link. Any help? I really need a way out from this issue. ThanksnViewing 2 reply threads- The topic ‘Issue with thermal result’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4007
1461
1287
1124
