Ansys Free Student Software
Not able to install ansys 2020 R2 and 2019 R3
    • anurag57
      Downloaled ansys 2020R2 and 2019R3 but on clicking run as administrator it shows nothin, no error message occur. n
    • anurag57
      _I am not able to install ansys 2020 r2 and ansys 2019 r3 for students n
    • anurag57
      _n
      Have you extracted the zip files? Do not try and install from inside the archive. n
    • anurag57
      _yes i extracted the zip file n
    • ANSYS_MMadore
      Did you disable all antivirus applications? When you right-click -> Run as administrator, do you see any setup process start in the Task Manager?n
    • anurag57
      _I already uninstalled antivirus and no setup process start in the task manager while doing run as administrator.n
    • George Karnos
      If you open Windows Event Viewer and check The Windows Logs, does it show any errors or information concerning Ansys Setup?.
    • ANSYS_MMadore
      Can you try running a silent install? Open a Windows command prompt using right-click -> run as administrator. CD to the directory where the setup.exe resides, then run this command. nsetup.exe -silentnPlease note, if installing only 2019R3 you will need to update the license file as discussed in this thread.n/forum/discussion/19805/how-to-renew-ansys-student-product-licensen
    • anurag57
      _nn
    • George Karnos
      Array Click on the > next to Windows logs and then click on one of the log files.... Application or system or Setup or SecuritynYou should then see messages (Events) in the middle windown
    • anurag57
      nn
    • ANSYS_MMadore
      cd C:\users\dell\Downloads\ACADEMICSTUDENT_2019R3_WINX64nsetup.exe -silent -debugnnThere is a space between setup.exe and -silent, and before -debug.nn
    • anurag57
      _nn
    • anurag57
      _it asked for permission to run but nothing happensnnn
    • ANSYS_MMadore
      Array It is silent, it will run in the background. Please look to see if it created any C:\Program Files\Ansys Inc\Ansys Student directories, or if the setup.exe is running under the Details tab of your Task Manager. The -debug flag creates the  %temp%\ans_install_tmp####\debug.txt file, can you please copy the text from that log and share it?n
    • anurag57
      _nnothing is on program files and in temp files related to ansysn
    • George Karnos
      Can you check to make sure that all Window Defender Services are stopped.nVirus and firewall.nAfter they as well as any other Virus protection are topped, try installing again.nIf you dont feel comfortable shutting down the services, try checking the log files for the virus software to see if there are any messages about being blocked.n
Viewing 17 reply threads
  • The topic ‘Not able to install ansys 2020 R2 and 2019 R3’ is closed to new replies.
