January 7, 2021 at 7:17 pm
Nikke
SubscriberHi,
I would like to increase this text font size so that when I export the figure the title is bigger and more visible:
January 8, 2021 at 7:08 amKeyur Kanade
Ansys EmployeeI do not think these is any direct control. nYou can select it and drag to increase window of legend. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynnJanuary 8, 2021 at 7:11 amKeyur Kanade
Ansys EmployeeIf you are using 2020R2 then you have it under File - Preferences n
January 8, 2021 at 7:27 amNikke
SubscriberHi,nThank you Keyur! I got it working. Earlier I had tried to change the automatic font size in preferences but I realized now that the text behavior should be changed to Fixed Size after which a fixed font size can be determined. nBest regards,nNiklasnViewing 3 reply threads- The topic ‘Ansys Fluent: Changing the font size of the contour plot legend title’ is closed to new replies.
6309
