Fatal error in CFD-Post
    • Ramy
      I get this error (a screenshot attached below) when I try to "load results" in CFD-Post. The steps I do in details:
      1- Open a separate CFD-Post tool.
      2- Click "load results"
      3- Select the last time step ".cdat" file.
      Then I get that error. I don't even find that folder mentioned in the error. How can I solve this issue?
      Thanks
    • Keyur Kanade
      Is this error for this particular file or all files? It may happen that cdat file is corrupt. nCan you please do simple test case?nWrite .cas and .dat file from Fluent for a simple case. Then try to read in CFD-Post. nIf simple case also gives problem then there may be some installation issue. Please check if you can reinstall latest version available. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • Ramy
      Hi, nI installed the latest version and the same error occurs.nThanksn
    • Keyur Kanade
      Can you please do simple test case?nWrite .cas and .dat file from Fluent for a simple case. Then try to read in CFD-Post.nPlease check this in standalone CFD-Post. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
  • The topic ‘Fatal error in CFD-Post’ is closed to new replies.
