December 26, 2020 at 2:58 pm
pmeghana
SubscriberI am trying to simulate a steady state case of a settling chamber using DPM in fluent with a certain inlet water flow rate and I am injecting a surface type with a rosin rammler particle distribution. For my case, i have got 15 diameters and 80 cells in the inlet, hence the number of parcels tracked is showing me 1200. There is a certain amount of particles leaving the chamber through an outlet.nI input a certain certain amount of particle flowrate (kg/s) and i track the amount leaving my chamber domain. But i want to know the exact number of particles in the system. through my inlet distribution i can find out the input number of particles, but how do i find out the output one?nI am able to check out which of the parcels and the overall mass that escaped through my outlet. How do i find out the distribution of particles and the count in these parcels?n -
December 28, 2020 at 10:35 pm
Karthik Remella
AdministratorHi,nYou should be able to obtain this number based on Particle ID or you might have to do Sampling. nHere is some help on Data Sampling from the Fluent Users Guide.nI hope this helps.n -
January 4, 2021 at 8:30 am
pmeghana
SubscriberHinThankyou, but i could not find the DPM variables in the sampling option int he run calculation tab. nInstead i took results>discrete phase>sample and got the data from that. The particle ID here would be the parcel ID right? n( x y z u v w diameter t mass-flow mass frequency time name)nHere for a steady state calculations, would the frequency give me the number of particles in the parcel at a certain x,y,z?nThankyou!nn -
January 4, 2021 at 1:39 pm
Forum ModeratorParticle ID is the parcel, it's just a badly chosen term from the early versions of the code that tends to cause confusion as we track parcels rather than particles. Not sure about frequency, what values are you seeing? n -
January 4, 2021 at 4:10 pm
pmeghana
SubscriberThank you sir. My values are like the below:n( x y z u v w diameter t mass-flow mass frequency time name)n(( 1.0000e+01 9.2038e-01 8.9226e-01 3.0359e-05 1.9501e-05 -4.1512e-06 1.0000e-06 3.0000e+02 1.1971e-05 7.8540e-16 1.5242e+10 2.2184e+06) injection-0:615)nMultiplying mass and frequency gives me mass-flow value, does this mean frequency can be taken as particle per time? or is it something else?.
Viewing 4 reply threads
- The topic ‘Particle count in DPM’ is closed to new replies.
1306
