LS Dyna
LS Dyna
How to impose rotational velocity on a rigid body in Workbench LS-DYNA?
    • bobsik641
      Hello,nin Explicit Dynamics Autodyn, I would just create a cylindrical coordinate system and apply a velocity/displacement boundary condition.nHowever, it seems that cylindrical CSs are not supported by LS-DYNA...nWhat should I do to impose rotational velocity on a rigid shaft?.
    • Chris Quan
      In WB LS-DYNA system, you need to add a keyword *Boundary_Prescribed_Motion using keyword snippet to specify the rotation. An example model can be found in this web page at https://www.dynaexamples.com/introduction/examples-manual/load/presrcibed.nFor rotational motion, DOF is equal to one of 5, 6, 7, 8, -8, 9, -9, 10, -10, 11, -11.n
    • bobsik641
      Well, I guess I'll stick to the Autodyn Explicit Dynamics...nThank you for your time thoughn
  • The topic ‘How to impose rotational velocity on a rigid body in Workbench LS-DYNA?’ is closed to new replies.
