December 19, 2020 at 1:41 am
Cesar0103
SubscriberHello!!!!nI am working with a magnet assisted synchronous reluctance motor (PMa-SynRM) and I am trying to get the constant power characteristics. Without the assistance of the magnet I obtain the characteristic constant torque through the Machine Toolkit, but when I use the magnet the characteristic doesn't give me something reasonable. Does this kit not work for this type of machine?nCould you tell me if there is a tool to calculate the constant power characteristic or any suggestion to obtain it, any idea or suggestion is good....nnThanks!!!!!n -
January 5, 2021 at 4:39 pm
Navya C
Ansys EmployeeHi @CesarnPMASRM is also a kind of IPM machine. Machine toolkit supports IPM machine.nSo it should work for PMASRM as well I think.nnnBest regards,nNavyan -
January 12, 2021 at 2:17 pm
Cesar0103
SubscriberHi NavyanI tried to simulate it as an IPM but it gave me inconsistent results. I'll give it a try....nThanks for your time....nBest regards,nCesarn -
January 21, 2021 at 6:42 pm
Cesar0103
SubscribernI followed his advice and ran the simulation as a IPM machine, but the results I don't think are correct, I show younnwithout PMnnwith PMn
nTheoretically, the torque on the assisted machine must be higher, but it is not the case...the simulation was carried out under the same conditions.nBest regards,nCesarn
- The topic ‘FW and MTPA characteristic’ is closed to new replies.
Ansys Innovation Space
- Plotting Ex, Ey and Ez in vector forms individually
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
960
830
599
591
