December 10, 2020 at 3:55 am
zyao1
SubscriberDear everyone,
I met an error when I run shape optimization for a case via ACT in Fluent. Below picture is the console showing the error.
December 10, 2020 at 10:11 amRob
Forum ModeratorThe error is that you picked pressure-drop for the observable but it's not recognised in the panel. Check your definitions. Also check if you can deform poly mesh:it was limited to hex (smoothing/layering) and tet (smoothing/remeshing). nDecember 10, 2020 at 2:40 pmzyao1
SubscriberDear Bob,nThank you for your suggestions.nMay I check the last point you mentioned means: poly mesh does not work for shape optimization well? or Poly mesh does not work for the primary simulation? nThank younnZyaonDecember 14, 2020 at 3:03 pmRob
Forum ModeratorI can't remember if you can deform a poly mesh: so the optimiser will suggest some deformation but the mesh may not then move as it's poly. It'll be in the moving mesh section of the documentation somewhere. nViewing 3 reply threads- The topic ‘The meaning of error when running the shape optimization with ACT(Automatic Shape Optimization)’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4392
1494
1375
1209
