How to find shear rate in FLUENT
    • Tareq
      Dears,
      What is the method to get the shear rate in Fluent.
    • Amine Ben Hadj Ali
      Shear Rate of what? At what?nShear Rate is a quantity which can access for Contour Plots, Report Expression or UDF'sn
    • Tareq
      Hello, thank you on the replynI am looking to get the shear rate at the surface.nnExactly I am looking for geting the shear rate curve in the fluent post along the surface, I checked there but only i can see velocity..etc but no shear rate to make the plotnnBest Regards,nTareqnnn
      Check the variable under Derivatives Category.n
    • Tareq
      This is all what i found in the Ansys fluent post, but unfortuntaelty can not find shear ratennn
      Not all data is transferred from Fluent as some is calculated as needed. Have a look in Fluent, and you may need to add it to the data export. n
    • Tareq
      Thank you, below is all the data i can export from fluent, please is the shear rate is the strain rate or it caclualted by something else?nBest Regards,nTareqnnn
      Do use CDAT Export and select strain rate or better to do post-processing in Fluent. Shear Rate is the Strain Rate. n
    • Tareq
      Thank you n
Viewing 8 reply threads
  • The topic ‘How to find shear rate in FLUENT’ is closed to new replies.
