November 17, 2020 at 3:46 pm
Milhm
SubscriberHi,nnI am working on spray cooling.I want to spray water in a compressible flow.The stagnation pressure is 4Mpa and static pressure is 0.696Mpa.I set operating pressure to zero and i enter 4Mpa and 0.696Mpa in pressure inlet boundary conditions.I enabled species transport.In materials for mixture template, i select ideal gas for density, mixing law for Cp and Sutherland Law for viscosity.I use pressure swirl atomizer.nnAt the beginning of injection i recieve this error:# Divergence detected in AMG for pressure coupled: protective actions enabled!nn# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!nnError: Divergence detected in AMG solver: pressure couplednnWhat should I do?what is wrong?.nnRegardsnnMiladn -
November 17, 2020 at 3:52 pm
Forum ModeratorPlease answer the questions posted in nHi,I am working on spray cooling.I want to spray water in a compressible flow.The stagnation pressure is 4Mpa and static pressure is 0.696Mpa.I set operating pressure to zero and i enter 4Mpa and 0.696Mpa in pressure inlet boundary conditions.I enabled species transport.In materials for mixture template, i select ideal gas for density, mixing law for Cp and Sutherland Law for viscosity.I use pressure swirl atomizer.At the beginning of injection i recieve this error:# Divergence detected in AMG for pressure coupled: protective actions enabled!# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!Error: Divergence detected in AMG solver: pressure coupledWhat should I do?what is wrong?RegardsMilad/forum/discussion/comment/97471#Comment_97471
in THIS thread. Creating more threads/posts on this subject is highly not recommended. n -
November 17, 2020 at 7:04 pm
Milhm
SubscriberExcuse me.I did not know where and how should i ask my question.nWould you please answer my question?What should i do to simulate DPM in compressible flow?n -
November 18, 2020 at 9:28 am
DrAmine
Ansys EmployeeExcuse me.I did not know where and how should i ask my question.Would you please answer my question?What should i do to simulate DPM in compressible flow?/forum/discussion/comment/97691#Comment_97691
Can you try without particles first?n -
November 18, 2020 at 12:51 pm
Milhm
SubscriberAt first i run the simulation with compressible air.Air is ideal gas and sutherland law is used for viscosity.here operating pressure is zero and i enter 4Mpa and 0.696Mpa in pressure inlet boundary conditions.Fluent solves this problem without any error.Then i turn on species transport but i do not turn on Discrete phase model.I change my material from air to mixture template and i run the simulation again.Fluent solves this too without any error.nThen i turn on Discrete phanse.I want to use pressure-swirl-atomizer.At the beginning of injection i recieve this error:# Divergence detected in AMG for pressure coupled: protective actions enabled!n# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!nError: Divergence detected in AMG solver: pressure couplednnnI attached the paper that i want to simulate.nnBest regardsn -
November 18, 2020 at 1:47 pm
DrAmine
Ansys EmployeeAs Ansys staff I do not look into attached documents. You might post the title of the paper and doi, instead. Are you able to inject using surface injection? Can you post your injection settings.n -
November 18, 2020 at 2:17 pm
Milhm
Subscriberpaper: Numerical investigation of droplets-gas mixing performance in depth adjustable underwater launcher cooling chamber - Â https://doi.org/10.1108/EC-09-2017-0343nNo i am not able to inject using surface injection.nI should say after that error i get another error:nError: Invalid cp (0.000000e+00 J/kgK) for oxygen at temperature 1.#QNAN0 Kn I set Cp in material as mixing law.what is wrong with cp?.
I have four pressure swirl atomizer like this.n
November 18, 2020 at 2:27 pm
Forum ModeratorIf air is an ideal gas, where is the oxygen coming into the model? How many particle streams have you got? n -
November 18, 2020 at 2:38 pm
Milhm
SubscriberMy particles are droplet .I think to enable the droplet in injection settings, i should enable species transport. Is it correct?nI assumed 200 particle streams for any injection.n -
November 18, 2020 at 2:46 pm
Forum ModeratorIf they're evaporating, yes, you need species. If they're not evaporating you don't. That still doesn't explain why you have air and oxygen in the mixture. n -
November 18, 2020 at 2:53 pm
Milhm
Subscriberyes they are evaporating.nwhen i turn on species transport, the material of the domain changes from air to mixture-template. Mixture-template includes oxygen,nitrogen and water.n -
November 18, 2020 at 4:06 pm
Forum ModeratorI'd suggest changing it back to air, it's more efficient than solving for two inert gases. n -
November 18, 2020 at 4:23 pm
Milhm
Subscriberif i change it to air, i can not define water as an evaporating species. And i can not simulate evaporationn -
November 18, 2020 at 4:26 pm
Forum ModeratorYou need to add water to the mixture too. n -
November 18, 2020 at 5:59 pm
DrAmine
Ansys EmployeeAnd check the tutorial Evaporating Spray. n -
November 18, 2020 at 7:20 pm
Milhm
SubscriberYou need to add water to the mixture too./forum/discussion/comment/97838#Comment_97838
when i turn on species transport, the default material is named mixture template and it already includes water,oxygen and nitrogen.nwhat should i do?Should i delete oxygen and nitrogen from the mixture?.nI should say another thing.If i set the operating pressure to a value which is not equal to zero,Fluent solve problem without error.Fluent simulate evaporation without error.But the calculated values of pressure and velocity for example mach number anb absolute pressure for compressible flow... are not correct.nWhat should i do?n -
November 18, 2020 at 7:41 pm
DrAmine
Ansys EmployeeRemove oxygen from mixture material. I assume default equation of state is incompressible ideal gas. Fir low mach number flows provide an operating pressure no matter what you choose as EOS and adjust openings accordingly. -
December 6, 2020 at 9:25 am
Milhm
SubscriberI removed oxygen and nitrogen from material. i run the simulation and injection was done. but it is almost unable to cool the compressible crossflow. Droplets can not penetrate in the domin.what is the problem?I have a doubt if i had simulate the compressible crossflow correctly or not.nstagnation pressure:4MPa - static pressure:0.696MPa - stagnation temperature:500k - static temperature:303.5k - Mach number:1.8nI set the operating pressure to zero.My boundary conditions are pressure inlet and pressure outlet.nI send contours of the domain.Are they correct and meaningful?nThe values of turbulent kinetic energy and turbulent intensity are very high.Are they correct?nBest regrdsn
n
December 7, 2020 at 9:16 am
DrAmine
Ansys EmployeeHi, can you first try injecting one single particle or along the inlet surface? Moreover I cannot tell if the field are reasonable as you are not sharing an update about the used BC'sn
- The topic ‘DPM modelling in compressible flow’ is closed to new replies.
6029
