November 16, 2020 at 4:41 am
Van Toan Nguyen
SubscriberHello everyone!
I have the result files (.dat.gz) when I simulated by Fluent (as shown below).
The first files from "0000" to "60000' (denoted by time steps) were obtained and then the program was interrupted so I continued another simulation with the data file saved before. After that I had the result files from "60000" to "100000". However When I used CFD-Post processing to get animation, the time steps were loaded only from "00000" to "60000" or from "60000" to "100000". How can I get full time steps?
Thank you so much!
November 16, 2020 at 7:26 amAmine Ben Hadj Ali
Ansys EmployeeYou might need to adjust the content of the first cas file and add the missing time step specification there. Alternative is to use Ansys EnSight.nNovember 16, 2020 at 7:34 amVan Toan Nguyen
SubscriberThank you for your reply. How can I adjust the content of the .cas file?nNovember 16, 2020 at 7:35 amAmine Ben Hadj Ali
Ansys EmployeeEditing in Text Editor on your warranty!nNovember 16, 2020 at 7:35 amAmine Ben Hadj Ali
Ansys Employeehowever I recommend that you repeat the run and try to export cdat files: dat files in CFD-Post are not recommended!nNovember 16, 2020 at 11:43 amRob
Forum ModeratorIf you're messing in the case & data files I also recommend taking a copy. That way if it all goes wrong you don't lose any files. The other option is to post-process the first set of data and keep the State file, then run that state file on the second lot of data. nViewing 5 reply threads- The topic ‘How to combine the result files in Ansys?’ is closed to new replies.
4673
1565
1386
1236
