November 15, 2020 at 5:30 am
holmesthinking
SubscriberHi, when I'm trying to use beam end release in 2020 R2 I get an error:nOne of the nodes for a beam end release is not found. The solution can not proceed until this is fixed.nI have no idea why it doesn't workn -
November 19, 2020 at 11:11 am
Ashish Khemka
Forum ModeratornnConstraining multiple edges can give this issue. You can free the constraint of multiple edges at the vertexs location however you must always keep at least one edge from being released. nThis is documented here: nnPlease see if this helps.nnRegards,nAshish Khemkan -
November 19, 2020 at 2:30 pm
holmesthinking
Subscriberthank You for replay,nindeed there was a problem with scoping to multiple edges.n
- The topic ‘Beam end release error’ is closed to new replies.
Ansys Innovation Space
1193
1076
1063
952
