November 13, 2020 at 10:21 am
AskandLearn
SubscriberHinIs it possible to enter a specific volume inside an object in Ansys and use this volume to simulate using CFX?.n -
November 13, 2020 at 11:56 am
Forum ModeratorI'm not sure what you mean. We can extract a single region (geometry) from a larger assembly and having meshed just that can simulate it. So, for example, we can extract a valve and short length of pipe from a larger network to focus on the valve. n -
November 14, 2020 at 2:51 pm
AskandLearn
SubscriberI want to simulate the heat transfer inside a container with respectively, 10 mL, 20 mL and 30 mL. How can specify the volumes inside the container and be sure they are exactly 10 mL, 20 mL and 30 mL?n -
November 16, 2020 at 12:19 pm
Forum ModeratorYou can do this in the geometry tool, just label them before moving to meshing. Just make the volume at the size(s) required. n -
November 16, 2020 at 8:25 pm
AskandLearn
SubscriberIt is not easy to decide at which height I exactly I can get the different volume. Can I use a tool to tell the exact volume or should I visually do a couple of tries? n
Viewing 4 reply threads
- The topic ‘Decide volume to simulate an object’ is closed to new replies.
Ansys Innovation Space
1057
1051
965
942
