TAGGED: chaboche, curve-fitting, kinematic-hardening, metal, plasticity
November 12, 2020 at 9:43 am
AbelBerhanemeskel
SubscriberHello Everyone,
I was trying to model cyclic plasticity using chaboche Kinematic hardening model. I noticed that when you input a chaboche Kinematic hardening model a curve fitting option becomes available. When you include the curve fitting option a uniaxial plastic strain test data input area where it says add experimental data becomes available. Can anyone please explain to me how I can input the uniaxial plastic strain test data and how I can get the chaboche parameters?
Thanks.
November 22, 2020 at 6:31 pmViewing 1 reply thread- The topic ‘Curve Fitting Chaboche Kinematic Hardening Parameter Using Uniaxial Plastic Strain Data’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Shape Memory Alloy Deployment
- Correct Material Definition
- Softening Issues in Reinforced Concrete
- Material Designer – Material Assignment
- Error on Material Designer, One or more errors occurred.
- how to use Plastic material property of steel only
- Hydrogen Simulations
- Is there a simple data base of electronic parts, motors, resistors etc.
Top Contributors-
2928
970
852
599
591
