November 11, 2020 at 7:12 am
b.x. Yang
SubscriberHi, everyone nAs the question in title, nl, plwk and send, plastic, what's the difference of this two results .nIf you could answer this question, it will be nice!nn -
November 12, 2020 at 5:07 am
Govindan Nagappan
Ansys EmployeenHi Array nPlastic work per volume is the same as plastic strain energy density. nl, plwk and send, plastic should produce same resultsn NL (nonlinear) records existed for many years, and NL,PLWK was used by the older VISCO10x (viscoplastic, not viscoelastic) elements. nWhen 18x elements were introduced they had a SEND record. Legacy elements do not use SEND. The SEND records are only written when NLGEOM,ON is set. They include elastic, plastic, and creep strain energy density (i.e., work/volume). nn -
November 13, 2020 at 2:39 am
b.x. Yang
SubscriberThank you very much!n
- The topic ‘“plastic work/density” and “strain ennergy density”’ is closed to new replies.
1313
