November 10, 2020 at 10:07 am
Arunkumarmoovandan37
SubscriberEverything works finenBut fluent says 'fluent failed to start'.nBoth standalone and workbenchnBut when i use c:\program files\ansys inc\v191\fluenttbin\win64\fluent.exe in the cmd prompt It opens.n -
November 10, 2020 at 11:52 am
Forum ModeratorWhat does the Standalone launcher point at, all that's doing is use the command. n -
November 11, 2020 at 2:39 am
SubscriberWhen I try to open fluent through workbench it says fluent failed to start.nBut when I use that command it opens.n -
November 11, 2020 at 9:38 am
Forum ModeratorAnd using stand alone from the Start menu icon?n -
November 11, 2020 at 1:43 pm
SubscriberThat also doesn't opennBut when I use this in the command prompt c:\program files\ansys inc\v191\fluenttbin\win64\fluent.exen -
November 12, 2020 at 9:37 am
November 13, 2020 at 8:59 am
November 13, 2020 at 11:07 am
Forum ModeratorWhich version are you trying to launch? The command line you gave is R19.1 but the panel in the image you posted is R19.2 They're different installs so please check what is and isn't installed and which versions you're trying to launch with each method. n -
November 14, 2020 at 1:57 am
SubscriberIt is 19.2 not 19.1nn -
November 16, 2020 at 11:16 am
Forum ModeratorIf you use the command line that's R19.1 but the icon is pointed at R19.2 You can have both installed, but if the University licence manager is R19.1 then R19.2 will fail to launch. n -
November 17, 2020 at 1:08 pm
SubscriberNo I've installed only r19.2nThere's no other ansys versions installed in my pcn -
November 17, 2020 at 3:22 pm
Forum ModeratorOK, and the command line you're using to launch Fluent is c:\program files\ansys inc\v192\fluenttbin\win64\fluent.exe ? n -
November 18, 2020 at 1:23 am
SubscriberYesn -
November 18, 2020 at 1:24 am
SubscriberAfter whole pc reset it works finen
Viewing 13 reply threads
- The topic ‘Fluent doesn’t start’ is closed to new replies.
1307
