3D Design
3D Design
How to modelling a Mass-spring-damper system of two-body Point absorber WEC using Ansys Aqwa?
    • 512145
      Dear Colleague,nI would like to simulate a twobody Floating Point Absorber wave energy converter using Ansys Aqwa. Unfortunately, I have no idea to simulate a mass-spring-damper system that represents a Power take-off (PTO) system of WEC.nI look forward to your help to resolve this problem.nThanks in advance,n
    • Ashish Khemka
      Hi 512145 ,
      If the relative motion of the two bodies is piston-like, please define a pair of fenders fixing on one structure and contacting on another structure's surfaces, such as
      The fenders' stiffness and damping coefficients can be defined.
      If the relative motion of the two bodies is rotational about an axis or a point, please use a joint of hinge or universal or ball and socket (see Aqwa User's Manual, Section 3.7.6). The stiffness and damping of the joint can be defined.
      Ashish Khemka
    • hossein_r
      Hiakhemka
      Can you explain more about the picture please. Now structure 2 is fixed and 2 plates that you named structure 1 is the two body of the wave energy convertor or the dashed lines are? And what kind of fenders we should define for this? I mean omni-directional or one directional?
    • Ashish Khemka
      Hi hossein_r ,
      Please create a new discussion for the query.
      Ashish Khemka
  • The topic ‘How to modelling a Mass-spring-damper system of two-body Point absorber WEC using Ansys Aqwa?’ is closed to new replies.
