Exporting Report Plots
    • SaiD
      How can I export Report Plots to a file after I have run the simulation?n
    • RK
      Hello, n It is possible to do so with the command /plot/file-set/plot-to-file [filename]. After running 1 iteration, Fluent will dump all data used in all the plots into the specified file.n
  • The topic ‘Exporting Report Plots’ is closed to new replies.
