October 21, 2020 at 8:27 pm
bilalalameri
SubscriberOctober 21, 2020 at 8:28 pmbilalalameri
SubscriberANSYS trying to import model in software however software gets stuck in Mechanical window. it is stay like this for evernOctober 21, 2020 at 9:10 pmKarthik Remella
AdministratorHello,nI'm moving this question to the 'Structures' thread. What model are you trying to import? Could you please elaborate a little more here?nAlso, are you able to create a simple geometry and start modeling this at your end? Just checking to see if you are able to launch Ansys Mechanical.nThanks.nKarthiknOctober 22, 2020 at 1:12 pmGary_S
Ansys EmployeeOne thing you could try quickly is to clean the settings:nExit Ansys completely.nStart > RunnOr, in the Explorer address fieldnEnter: %APPDATA%n...An Explorer Window will opennOpen the Roaming folder...nOpen the Ansys folder...nRename the vNNN folder to vNNN.oldn (v201 = 2020R1, v202 = 2020R2, v195 = 2019R3, etc)nStart WB and try againnnGarynnViewing 3 reply threads- The topic ‘Have Problem’ is closed to new replies.
5084
1823
1387
1248
