TAGGED: 2-d, mesh-elements, mesh-generation, transient-structural
October 14, 2020 at 8:28 am
francescone96
SubscriberHi everybody, nI'm performing a 2D analysis on ansys transient structural. To be more precise i import a temperature field (variable with time) from fluent and then i process on transient structural to get the stress and the strain of the structure itself. nWell i have a problem with the tensional state of the 2D body:i want to get a plain strain while i get a plain stress. I checked on solution the mesh element and by default i have SHELL181 which has 6 DOF (UX,UY,UZ,ROTX,ROTY,ROTZ). How can i change the mesh element to a planar element with just the plane dof? For instance PLANE42 or another one with only UX,UY,ROTZ degrees of freedom? nI also tried to import my mesh to mechanical APDL, but i suppose i'm not good at it since i get errors on importing and so on... nThank in advance!n -
October 15, 2020 at 8:52 am
October 15, 2020 at 11:24 am
francescone96
Thank you for the fast answer. nBy activating the option plain strain under Geometry tree i get another error:The addin does not support transfer of data for 2D models. Please delete the load before you proceed. and so i cannot transfer the information from Fluent to Transient Structural. The imported body temperature is not loaded on Transient structural module and in this way i can't go on with the structural simulation. How can i solve this?Thank in advance!
October 15, 2020 at 1:33 pm
Rahul Kumbhar
Ansys EmployeeCan you create a new question in fluid mechanics section so fluent users can guide you. I assume there could be some settings in Fluent to export the data for 2D analysis.n -
October 15, 2020 at 1:42 pm
francescone96
SubscriberOk, thank you a lot rkumbhar nn -
October 16, 2020 at 9:11 am
francescone96
ArraynEven if i checked this option of plain strain i carry on getting the strain along Z different from zero ( z direction is the normal direction of my 2D analysis).nI read that plain strain means automatically that the strain along the normal direction has to be zero, this is not happening. Do i have to check also the KeyOption of the element? nThank in advancen
October 16, 2020 at 9:17 am
francescone96
This is the result with the plain strain. I'm only computing strain and stress since i'm performing this simulation just to solve the problem. The geometry is very similar to the one of my real problem. But still despite plain strain option, i get Zstrain different from zero. What am i doing wrong?n
October 16, 2020 at 11:39 am
Rahul Kumbhar
Ansys EmployeeIn order to debug one need to look into the WB file which Ansys employees are not allowed. You can upload the file so other volunteers can pitch in and help. Or you can create a new thread which will be more visible to other volunteers and upload the file there.nn
Viewing 7 reply threads
- The topic ‘2D element type in workbench’ is closed to new replies.
1324
1047
