October 3, 2020 at 10:35 pm
shisha3301
SubscriberOctober 3, 2020 at 10:51 pmBrunoSilva
SubscriberI suggest you to apply a pressure on one edge with the value of Sigma nominal and apply either a fixed support condition on the other edge or a displacement condition of ux = 0 (assuming x as the direction of the loading).nI personally like to apply displacement ux = 0 on the other edge, If you do this then you need to turn off Solver Pivot Checking in Analysis Settings.n
nIn my example, I considered Sigma nominal equal to 5 MPa.nn
I got 15,32 MPa as a result, you have to remember that the famous factor of 3 is the solution for an infinite plate, so if you want to get closer to that answer you could either consider a smaller circle or a bigger plate.
October 6, 2020 at 7:29 pmdanielshaw
Ansys EmployeeI agree with Bruno's recommendation. Applying a fixed restraints provides numerical stability, If for some reason, you must have equal and opposite pressures applied, you might be able to obtain a converged solution by turning weak springs ON. nViewing 2 reply threads- The topic ‘Stress Concentration Factor Plate with Hole’ is closed to new replies.
6485
