October 2, 2020 at 6:06 pm
Gotta_Go_Fast
SubscriberHello all,
I am attempting to create a user defined result to calculate the safety factor of my beam-modeled chassis. I have done the following:
- Successfully solved my model
- Evaluated the Maximum Combined Stress for my model
- Found the code for Maximum Combined Stress (BEANMAX_COMBINED) in the solution worksheet
- I found the yield strength of material I am using, which is 250 MPa.
- I created a user defined result that with the following parameters:
October 21, 2020 at 12:41 pmAshish Khemka
Forum ModeratornnI think your data in BEANMAX_COMBINED contains a zero value and that is causing the error. You can calculate 1/ FoS.nnRegards,nAshish KhemkanViewing 1 reply thread- The topic ‘User defined result to find safety factor with beams’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
Top Contributors-
4597
1495
1386
1209
