October 2, 2020 at 5:28 pm
SaiD
Ansys EmployeeHow to get the Element/Node Count in the model without running it?n -
October 2, 2020 at 7:21 pm
Kai
Ansys EmployeeFor getting the count of elements or nodes, you can use *GET command. Basically, with this you can store the value of count in a parameter. Command for element count of selected elements; *GET, E_COUNT, ELEM,,COUNT Command for node count of selected nodes; *GET, N_COUNT, NODE,,COUNT In above commands, E_COUNT and N_COUNT are parameters name respectively. You can check the values of those parameters under Parameters//Scalar Parameters.n
- The topic ‘Getting element and node count in Mechanical APDL’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1482
