TAGGED: iges, parasolid, solidworks, spaceclaim-directmodeler, volume-extract
September 22, 2020 at 1:19 pm
Xbuddyin
SubscriberDear Guys,nI am trying to simulate the flow through the valve, I have made my model in the solid works and try to import in the Ansys Space claims for further steps like : Repairing and creating the Volume Extract. nI have always use IGES(.IGS)as format imported from the solid work to Ansys. I found that during the Import of IGES, I got a lot of extra edges to repair? Does it matter If I use Parasolid format(.xt) ? Is there any best format I can choose for my application? Choosing any format will also effect the volume extract in the fluent?nthanksn -
September 22, 2020 at 2:30 pm
Gary Stofan
Ansys EmployeeThe IGES and STEP formats have not been enhanced in many years, and are not recommended for complex geometries. nJust like translating languages, the least number of steps is often the most accurate.nDepending on CAD version and your licensing, you should be able to import SolidWorks directly into SpaceClaim.nSpaceClaim can then attach into Ansys Workbench applications.
- The topic ‘Which is Best Solidwork format imported for Ansys?’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1431
1272
1119
1015
