TAGGED: fluid-flow, fracture, smart, structural-mechanics
September 16, 2020 at 9:50 am
Simon Shi
SubscriberHello everybody. Currently I am trying to simulate the influence of different fluids on the cracking behavior of polymer materials. Ultimately, my challenge is to predict the crack growth behavior within these fluids. In theory, the absorption of the fluid into the material leads to pressure within the material and a reduction of stress intensity factor and ultimately, premature failure. Does anybody have a suggestion as to how to best model this behavior/ if it is possible using the SMART feature? n -
September 17, 2020 at 5:43 pm
David Weed
Ansys EmployeeHi,nDo you know how the fluid will disperse throughout the material? If it will infiltrate open cracks and you know the magnitude and distribution of the pressure it causes, you may consider applying this to the crack faces. These sections in the MAPDL Fracture Analysis Guide explain how to do this using MAPDL commands: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_frac/fracSMART.htmln3.2.1.4.4. Normal Surface Pressure Loadn3.2.1.4.5. Normal Surface Pressure Load to New Crack Surfacesn -
October 1, 2020 at 2:39 pm
Simon Shi
SubscriberI?ll give it a try, thanks! n
- The topic ‘Is SMART crack feature able to integrate influence of an fluid environment?’ is closed to new replies.
1311
