September 12, 2020 at 11:37 am
JorgeP
SubscriberHello dear friends,
I'm doing a simulation following this tutorial: https://www.youtube.com/watch?v=6xAb9rdZugs&ab_channel=LEAPAustralia
I've created a bounding box for my domain and for my constant resolution zone. To do the wrapping, I select extract edges, create intersection loops collectively and shrink wrap but only with my domain and surface.
Now I need to create a bounding box to define my boundary layer limits. My problem is, if I create it and then select Extract Edges create intersection loops and shrink wrap together with the domain and surface, it will create a domain smaller than I need. But if I don't select the boundary layer box it won't appear on my scoped functions for boundary layer.
Basically what I need is that my boundary layer bounding box appears on the place I show at the following image but without messing my domain geometry.
September 14, 2020 at 4:04 pmRob
Forum ModeratorIf you have good CAD do you need to use the wrapper? The CleanCAD workflow should then be much easier to use. nViewing 1 reply thread- The topic ‘How to create a bounding box just to define boundary layer’ is closed to new replies.
6635
1312
