September 3, 2020 at 8:17 am
imselva26
SubscriberDear all,
In order to understand, the Equivalent stress values, I have reduced my model with just 3 parts.
It has a heating pipe, to which electricty is supplied and it is heated. The heating pipe is surrounded by insulator. The heating pipe is heated to 850 °C.
Now I want to do the structural analysis, the bottom of the heating pipe is given an external displacement (all the values are zero). The deformation I got is around 4.5 mm and the Equivalent Von mises stress is over 100Mpa.
I just want to understand, why this is hapennig? Is it because of the material properties? or is it because of the boundary conditions?
It is a very simple geomentry, and I wish to get the Equivalent stress well below 3.4Mpa which is given in the material data sheet.
Thank you
September 4, 2020 at 11:56 amAshish Khemka
Forum ModeratornnThe high stress appears to be becaue of thermal condition applied.nnRegards,nAshish KhemkanViewing 1 reply thread- The topic ‘Equivalent stress (von Mises) is higher than the yield strength’ is closed to new replies.
6485
