September 3, 2020 at 7:06 am
hameed
SubscriberHy
I am working to simulate the axial flux permanent magnet machine i have design all the parameters of model and analyze the setup but the results are not according to standard i need pure sine wave having value in volts (5 to 10V)
September 4, 2020 at 11:47 amAshish Khemka
Forum ModeratorHi,nnI am moving this post to Electromagnetics.nnRegards,nAshish KhemkanSeptember 4, 2020 at 10:23 pms3740222
Subscriberhi Ashish,nWhere can i see electromagnetics forum ?nRegardsnSeptember 12, 2020 at 11:08 amhameed
SubscriberHynHow can i contact electromagnetism forum..; nSeptember 15, 2020 at 10:29 amNKC
Forum ModeratorHi,nCheck the following.nIf your excitation current values, number of turns defined are correct. nAlso, speed of the machine defined is directly proportional to the magnitude of voltage developed.nIf the impedance of your winding is more, machine can't generate enough back emf.nThe phase shift and shape of the waveform are dependent on your winding arrangement and physical design.nThe issue could be mainly related to the design factors rather than the Analysis error.nIf the problem is still not resolved, Provide us with necessary screen shots to understand your design, setup details along with the vesion of Maxwell release you are using.nnRegards,nNavyanSeptember 15, 2020 at 11:10 amhameed
SubscriberHynThanks sir for your feedback i have check all the parameters you asked to review in the post.nI have design a axial flux permanent magnet machine on autocad that figure are attached with all parameters and then i export .sat file from autocad 2020 to ansoft maxwell 2013 model and then assign all parameters motor setup cylinder and outer region also draw in autocad file after that i assign the section of windings as coil terminals as attached in figure i have not applied any current or voltage in the windings i just applied motion setup 32000 rpm to both rotors havings permanent magnets and want to get the sinusoidal back emf with nomimal voltage (10V) nin the stator windings. I set the outer region as a insulating body as shown in figure. nKindly guide nThanks. nBest regardsnSeptember 15, 2020 at 11:57 amNKC
Forum ModeratorHi,nAs an Ansys employee, we are not authorized and can not access any attachments.nAlso we can not guide you directly on your projects or homeworks. But we can provide enough support related to using Ansys software tools.nPlease use upload image option and not the upload file option. Or just copy paste the screenshots.nnRegards,n NavyanSeptember 16, 2020 at 12:48 pmSeptember 19, 2020 at 4:08 amhameed
SubscriberHynSirnAccording to your requirements i have send you the necessary screenshot please review it and replynThanksnnSeptember 25, 2020 at 11:53 amNKC
Forum ModeratorHi Hameed,nOne thing which I noticed is you are using Ansoft Maxwell13 version - We can only provide support on Ansys tools from R18 to latest version. We suggest you upgrade your version.nWith that said, I have seen the screen shots you have posted and here are the suggestions I can provide for you to check.nIn addition to the above please do the following checksnRun the simulation in Magnetostatic solution and check flux density value in the airgap. If you calculate the induced emf using this flux density and turns in the formula you should get a close value to your requirement. If not either the number of turns is less or you need to use a stronger magnet. This will address the magnitude portion of the waveform.nComing to the shape - As suggested in the above post it is a design factor dependent on the magnet and stator configuration you used (magnet placement and winding distribution). Please connect with the authors of the IEEE paper you are referring to understand if you are missing something and also to learn more about how they dealt with harmonics(this could be another reason).nIf you think magnetization direction is incorrect, Please refer to the Maxwell help documentation to learn more about this topic. nRegardsnNavyanSeptember 25, 2020 at 5:15 pmhameed
SubscriberThanks sir nI have get the sinusoidal voltage having nominal magnitude n??nViewing 10 reply threads- The topic ‘Not getting pure sine wave and volatage magnitude’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
Top Contributors-
4633
1540
1386
1225
