August 7, 2020 at 7:37 am
labolatory
SubscriberI'm currently doing a thermo-fluid analysis. For example, how do I set if I want to have temperature fluctuations at only one point?nWith the standard initialization of fluent's initial setting, all cells are given the same temperature as initial conditions.n -
August 7, 2020 at 10:27 am
Forum ModeratorIf you want a temperature to fluctuate you'll need a transient boundary or cell zone (source term or FIX) condition. n -
August 12, 2020 at 5:00 am
labolatory
SubscriberEnergy is defined in the cell zone (source term or FIX) condition.nWhat if I want to define the temperaturen -
August 12, 2020 at 8:38 am
Forum ModeratorAt the start or during the run?n -
September 14, 2020 at 2:04 am
labolatory
Subscriberstart runn -
September 14, 2020 at 12:58 pm
Forum ModeratorIf it's just an initial condition use a Patch. Initialise with uniform values and then patch regions that are a different temperature. n -
September 15, 2020 at 5:19 am
labolatory
SubscriberThank you very much.nHow should I set up a Patch?nI don't know how to use it, so please let me know.n -
September 15, 2020 at 12:41 pm
Forum ModeratorLook in the initialise section from the tree menu, once you initialise the model click on Patch and have a look around. You may need to create an adaption register to give yourself a region to use in the patch function. nIn Google look for fluent patch region and you'll see some YouTube videos.n
Viewing 7 reply threads
- The topic ‘About setting the initial conditions’ is closed to new replies.
- affinity not set
1487
1318
1156
