August 5, 2020 at 10:14 am
a.m.aanikce
SubscriberI am following a tutorial on ANSYS for RCC Beam.
https://www.youtube.com/watch?v=oOQ4_jIjHkE
But the problem is that the top rebars are behaving as an independent body and is not showing any sign of meshing.
As per the tutorial the rebar should behave as following:
August 5, 2020 at 1:34 pmAniket
Forum ModeratorDo you have same mesh size on rebars and concrete? n-AniketnHow to access Ansys Online Help DocumentnnAugust 8, 2020 at 5:59 ama.m.aanikce
SubscriberYes.nAugust 10, 2020 at 12:42 pmAniket
Forum Moderatorso are you sure that the nodes are being bonded with the tolerance that you are using (0.1)? Does it help having larger tolerance? I will also recommend cutting the solid and having a shared topo only for solids excluding beams so you have a node at every location in the solid where you have beam nodes.n-AniketnHow to access Ansys Online Help DocumentnOctober 6, 2020 at 11:03 amKeyur Kanade
Ansys EmployeeThanks Aniket!nViewing 4 reply threads- The topic ‘The Top Rebars remain unmeshed.’ is closed to new replies.
3597
1273
1107
1068
953
