August 3, 2020 at 3:02 am
Keyur Kanade
Ansys EmployeeHow to create a surface body from faceted data in SpaceClaim? -
August 3, 2020 at 4:17 am
prajput
You can use Skin Surface feature under Tools tab to create surface patches from the faceted data. Once you have the faceted data, using Skin Surface feature you can select the facets by taking reference of underlying faceted data points, and thus create patches. Later on, you can stitch those pathes to create surface body.
August 3, 2020 at 10:01 am
Keyur Kanade
Ansys EmployeeThe Auto skin tool is not working on my model. When should I use Auto skin? -
August 3, 2020 at 10:21 am
prajput
The auto skin works on faceted body which is relatively smooth and error free.Â
August 3, 2020 at 10:33 am
Keyur Kanade
Ansys EmployeeWhen I use box selection, it does not work. Can you please suggest workaround? -
August 3, 2020 at 10:50 am
Karthik Remella
AdministratorThis could be since the model has large facets. Try remesh the facets using 'Regularize' command and then use 'Skin Surface'
Viewing 5 reply threads
- The topic ‘How to create a surface body from faceted data in SpaceClaim?’ is closed to new replies.
Ansys Innovation Space
1258
1102
1068
953
