July 31, 2020 at 3:56 pm
Akismet
SubscriberWhat is harmonic analysis?
Karthik Remella
AdministratorHarmonic analyses are used to determine the steady-state response of a linear structure to loads that vary sinusoidally (harmonically) with time, thus enabling you to verify whether or not your designs will successfully overcome resonance, fatigue, and other harmful effects of forced vibrations.
Dragana Jandric
Forum ModeratorHello, Harmonic loads of known magnitude and frequency are applied, sometimes multiple loads all at the same frequency.
- The topic ‘What is harmonic analysis?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
1487
1363
1194
