July 31, 2020 at 1:21 pm
prajput
When you drag a flat plate in the water, the water will be also moving along with the plate? What is driving it? -
July 31, 2020 at 1:22 pm
Keyur Kanade
Ansys EmployeeHello,Â
It is primarily due to the shear stress, which is the force tending to cause deformation of a material by slippage along a plane or planes parallel to the imposed stress. The resultant shear is of great importance in nature, being intimately related to the down slope movement of earth materials and to earthquakes. Shear stress may occur in solids or liquids; in the latter it is related to fluid viscosity.
- The topic ‘When you drag a flat plate in the water, the water will be also moving along with the plate?’ is closed to new replies.
- affinity not set
1487
1338
1171
