July 25, 2020 at 1:49 pm
Dyyo24
SubscriberHello:
I have a general question here. I have been running simulation on the compression deformation of 200um long and 10 um x um cross section beams in a large elastic material substrate of size larger than 1cm x 1cm x 1cm. The compression force is small and the deformation is not causing much bending. I ran into convergence problems in my previous runs and I am concerned about the small size of my um structure. Is it possible that I could simulate such small features into convergence? I have been using Mechanical 2019 R2.
Thank you!
Dyyo
Viewing 0 reply threads
- The topic ‘Convergence on um scale structure wrapped in cm scale material’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
1487
1363
1194
