Anisotropic Thermal Conductivity with Density-based solver in Ansys Fluent
    • deeps
      I am trying to solve a conjuage heat transfer problem involving high speed flow - which requires the use of density-based solver. The material I am using has anisotropic properties, but anisotropy is not supported in density-based solver (mentioned in Fluent Documentation). Is there any workaround for this?
      Thank you.
      Channel Partner
      If it's covered as a limitation then, no, there isn't a workaround. However... How high a speed are you looking at?
