July 17, 2020 at 2:45 pm
amberchow
SubscriberHello, I am trying to simulate how a magnet would affect a magnetic nanoparticle by applying some sort of external magnetic field in the ANSYS workbench software, but am having a hard time figuring out how. Any suggestions would be appreciated
July 17, 2020 at 3:17 pm
Mark Christini
Ansys EmployeeSee Maxwell 3D online help topic: Tangential H Field under Magnetostatic Boundaries.
July 30, 2021 at 2:48 pm
LukBlaz
Subscriber.may i ask a question semi-related to the topic?
i also need an external magnetic field, but for my calculations i need the transient solver, how do you manage to make an external field with the transient, as tangential H field boundaries are not available in transient?
i also tried to make the external field in magentostatic and link the result into my transient solution without results so far.
appreciate any response
BR
- The topic ‘External Magnetic Field’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3887
1414
1241
1118
1015
