August 8, 2026 at 12:22 pm
PL Zhang
SubscriberHello,
I created a very simple LS-DYNA implicit model to test simple restart with cohesive elements.
The model runs normally in a continuous implicit analysis. However, when I perform a simple restart using a
d3dump file, the analysis fails in the first implicit step after the restart.I tested both:
ÂELFORM = 19 ELFORM = -19Âand the same problem occurs with both cohesive element formulations.
I have attached the minimal
.ktest model, as well as the correspondingmessagfiles from the continuous analysis and the restart analysis.Is this a known limitation or bug related to cohesive solid elements in implicit simple restart? If simple restart is required for an implicit analysis, is there another cohesive element formulation that is recommended?
Thank you.
K file:$# LS-DYNA Keyword file created by LS-PrePost(R) 2025 R1 (v4.12.9) - 16Oct2025$# Created on Jul-1-2026 (16:49:32)*KEYWORD  Â*CONTROL_ACCURACY$#   osu    inn   pidosu    iacc   exacc   srtflg     1     4     0     1    2.0     0*CONTROL_BULK_VISCOSITY$#    q1     q2    type   btype   tstype    0.0    0.0     1     0     0*CONTROL_ENERGY$#   hgen    rwen   slnten   rylen   irgen   maten   drlen   disen     2     2     2     2     2     1     1     1*CONTROL_HOURGLASS$#   ihq     qh     6    0.01*CONTROL_IMPLICIT_AUTO$#  iauto   iteopt   itewin   dtmin   dtmax   dtexp   kfail   kcycle     1     11     51.00000E-7   0.001    0.0     0     0*CONTROL_IMPLICIT_DYNAMICS$#  imass   gamma    beta   tdybir   tdydth   tdybur   irate   alpha     0    0.5    0.25    0.01.00000E281.00000E28     0    0.0*CONTROL_IMPLICIT_GENERAL$#  imflag    dt0   imform    nsbs    igs   cnstn    form   zero_v     1   0.001     2     1     0     0     0     0*CONTROL_IMPLICIT_SOLUTION$  NSOLVR   ILIMIT   MAXREF   DCTOL   ECTOL   RCTOL   LSTOL$#  nsolvr   ilimit   maxref   dctol   ectol   rctol   lstol   abstol    12     1     301.0000E-101.0000E-101.00000E-5    0.9    0.0$   DNORM   DIVERG   ISTIF  NLPRINT   NLNORM$#  dnorm   diverg   istif  nlprint   nlnorm  d3itctl   cpchk    -1     1     1     3     2     0     0$   DMTOL   EMTOL   RMTOL        NTTOL   NRTOL   RTTOL   RRTOL$#  dmtol   emtol   rmtol     -   nttol   nrtol   rttol   rrtol1.0000E-101.0000E-101.00000E-4         0.0    0.0    0.0    0.0$  ARCCTL   ARCDIR   ARCLEN   ARCMTH   ARCDMP$#  arcctl   arcdir   arclen   arcmth   arcdmp   arcpsi   arcalf   arctim     0     0    0.0     1     2    0.0    0.0    0.0$#  lsmtd   lsdir    irad    srad    awgt    sred   kssize     6     2    0.0    0.0    0.0    0.0     10*CONTROL_IMPLICIT_SOLVER$#  lsolvr   lprint   negev   order    drcm   drcprm  autospc  autotol     7     1     2     0     4    0.0     1    0.0$#  lcpack   mtxdmp   iparm1   rparm1   rparm2     -   rparm4   rparm5     2     0    5001.00000E-9   0.001        240.0    0.0$#  emxdmp   rdcmem   absmem  isingle  iblropt     -    ispd   memlvl     0    0.95    0.0     0     0          0    0.0*CONTROL_TERMINATION$#  endtim   endcyc   dtmin   endeng   endmas   nosol 3.260E+01     0    0.0    0.0    0.0     0*CONTROL_TIMESTEP$#  dtinit   tssfac    isdo   tslimt   dt2ms    lctm   erode   ms1st    0.0    1e-5     0    0.0    0.0     0     0     0$#  dt2msf  dt2mslc   imscl   unused   unused   rmscl   emscl    ihdo    0.0     0     0              0.0    0.0     0*DATABASE_EXTENT_BINARY$#  neiph   neips   maxint   strflg   sigflg   epsflg   rltflg   engflg    80     3     3     1     1     1     1     1$#  cmpflg   ieverp   beamip   dcomp    shge   stssz   n3thdt  ialemat     0     0     4     1     1     1     2     0$# nintsld  pkp_sen    sclp   hydro   msscl   therm   intout   nodout     8     0    1.0     0     0     0STRESS   STRESS$#   dtdt   resplt   Â     0     0     3*DATABASE_BNDOUT$#    dt   binary    lcur   ioopt  option1  option2  option3  option4   0.01     2     0     1     0     0     0     0*DATABASE_GLSTAT$#    dt   binary    lcur   ioopt   0.01     2     0     1*DATABASE_MATSUM$#    dt   binary    lcur   ioopt   0.001     2     0     1*DATABASE_SPCFORC$#    dt   binary    lcur   ioopt   0.01     2     0     1*DATABASE_BINARY_D3PLOT$#    dt    lcdt    beam   npltc   psetid   0.001     0     0     0     0$#  ioopt    rate   cutoff   window    type    pset     0    0.0    0.0    0.0     0     0*DATABASE_BINARY_D3DUMP$#    dt    lcdt    beam   npltc   psetid     1     0     0     0     0*LOAD_SEGMENT   10001   0.5E6     0     13     14     16     15*DEFINE_CURVE$#   lcid    sidr    sfa    sfo    offa    offo   dattyp   lcint   10001     0    1.0    1.0    0.0    0.0     0     0$#         a1          o1 0.000000000000E+00  0.000000000000E+00 5.000000000000E-01  1.000000000000E+00 6.000000000000E-01  1.000000000000E+00 3.260000000000E+01  1.000000000000E+00*BOUNDARY_PRESCRIBED_MOTION_SET$#   nsid    dof    vad    lcid     sf    vid   death   birth     2     1     2   10000    1.0     0    0.0    0.0*DEFINE_CURVE$#   lcid    sidr    sfa    sfo    offa    offo   dattyp   lcint   10000     0    1.0    1.0    0.0    0.0     0     0$#         a1          o1 0.000000000000E+00  0.000000000000E+00 6.000000000000E-01  0.000000000000E+00 1.133333333333E+00  8.000000000000E-03 2.200000000000E+00 -8.000000000000E-03 2.733333333333E+00  0.000000000000E+00 3.266666666667E+00  8.000000000000E-03 4.333333333333E+00 -8.000000000000E-03 4.866666666667E+00  0.000000000000E+00 5.400000000000E+00  8.000000000000E-03 6.466666666667E+00 -8.000000000000E-03 7.000000000000E+00  0.000000000000E+00 7.533333333333E+00  8.000000000000E-03 8.600000000000E+00 -8.000000000000E-03 9.133333333333E+00  0.000000000000E+00 9.666666666667E+00  8.000000000000E-03 1.073333333333E+01 -8.000000000000E-03 1.126666666667E+01  0.000000000000E+00 1.180000000000E+01  8.000000000000E-03 1.286666666667E+01 -8.000000000000E-03 1.340000000000E+01  0.000000000000E+00 1.393333333333E+01  8.000000000000E-03 1.500000000000E+01 -8.000000000000E-03 1.553333333333E+01  0.000000000000E+00 1.606666666667E+01  8.000000000000E-03 1.713333333333E+01 -8.000000000000E-03 1.766666666667E+01  0.000000000000E+00 1.820000000000E+01  8.000000000000E-03 1.926666666667E+01 -8.000000000000E-03 1.980000000000E+01  0.000000000000E+00 2.033333333333E+01  8.000000000000E-03 2.140000000000E+01 -8.000000000000E-03 2.193333333333E+01  0.000000000000E+00 2.246666666667E+01  8.000000000000E-03 2.353333333333E+01 -8.000000000000E-03 2.406666666667E+01  0.000000000000E+00 2.460000000000E+01  8.000000000000E-03 2.566666666667E+01 -8.000000000000E-03 2.620000000000E+01  0.000000000000E+00 2.673333333333E+01  8.000000000000E-03 2.780000000000E+01 -8.000000000000E-03 2.833333333333E+01  0.000000000000E+00 2.886666666667E+01  8.000000000000E-03 2.993333333333E+01 -8.000000000000E-03 3.046666666667E+01  0.000000000000E+00 3.100000000000E+01  8.000000000000E-03 3.206666666667E+01 -8.000000000000E-03 3.260000000000E+01  0.000000000000E+00*SET_NODE_LIST$#   sid    da1    da2    da3    da4   solver    its     -     2    0.0    0.0    0.0    0.0MECH        1     Â$#   nid1    nid2    nid3    nid4    nid5    nid6    nid7    nid8     9     10     11     12     13     14     15     16*BOUNDARY_SPC_SET$#   nsid    cid    dofx    dofy    dofz   dofrx   dofry   dofrz     2     0     0     1     0*BOUNDARY_SPC_SET$#   nsid    cid    dofx    dofy    dofz   dofrx   dofry   dofrz     1     0     1     1     1*SET_NODE_LIST_TITLENODESET(SPC) 1$#   sid    da1    da2    da3    da4   solver    its     -     1    0.0    0.0    0.0    0.0MECH        1     Â$#   nid1    nid2    nid3    nid4    nid5    nid6    nid7    nid8     1     2     3     4     5     6     7     8*MAT_ELASTIC_TITLEROCK_OUTTER$#   mid     ro     e     pr     da     db  not used     1    2700 1.700E+10    0.23     0     0     0*MAT_COHESIVE_ELASTIC_TITLECOHESIVE     2 1.000E-06     1     0 2.400E+09 3.000E+10 1.000E+20 1.000E+20*MAT_ELASTIC_TITLEROCK_OUTTER$#   mid     ro     e     pr     da     db  not used     3    2700 1.700E+10    0.23     0     0     0*SECTION_SOLID$#   secid   elform     1     2*SECTION_SOLID$#   secid   elform     2     19*PART$#                                     titleboxsolid$#   pid   secid    mid   eosid    hgid    grav   adpopt    tmid     1     1     1     0     0     0     0     0*PART$#                                     titleboxsolid$#   pid   secid    mid   eosid    hgid    grav   adpopt    tmid     2     2     2     0     0     0     0     0*PART$#                                     titleboxsolid$#   pid   secid    mid   eosid    hgid    grav   adpopt    tmid     3     1     3     0     0     0     0     0*NODE$#  nid        x        y        z    tc    rc    1       0.0       0.0       0.0    0    0    2       0.15       0.0       0.0    0    0    3       0.0       0.15       0.0    0    0    4       0.15       0.15       0.0    0    0    5       0.0       0.0      0.075    0    0    6       0.15       0.0      0.075    0    0    7       0.0       0.15      0.075    0    0    8       0.15       0.15      0.075    0    0    9       0.0       0.0      0.075    0    0   10       0.15       0.0      0.075    0    0   11       0.0       0.15      0.075    0    0   12       0.15       0.15      0.075    0    0   13       0.0       0.0       0.15    0    0   14       0.15       0.0       0.15    0    0   15       0.0       0.15       0.15    0    0   16       0.15       0.15       0.15    0    0*ELEMENT_SOLID$#  eid   pid    n1    n2    n3    n4    n5    n6    n7    n8    1    1    1    2    4    3    5    6    8    7    2    2    5    6    8    7    9    10    12    11    3    3    9    10    12    11    13    14    16    15*END
messag01 file after simple restart:read d3dump1337 file
BEGIN implicit statics step 1337 t=1.3370E+00
Linear step computed
Initial translational energy = NaN
Initial total energy     = NaN
Initial residual norm     = NaN
Translational nodes norm   = NaN
