Rotational Velocity in Rigid Dynamics
    • kdh195
      I am using rigid dynamics for simulating simple model by using joint rotational velocity as my input.
      But I get some error: "Error creating joint condition. Check the syntax of the expression or the smoothness of the tabular data."
      Tabular Data
      Steps      Time       Rotational Velocity [rpm]
      1               0               0
      1               1               0                                             << NO ERROR
      1               2               0
      1               3               3
      1               0               0
      1               1               0                                             << ERROR !
      1               2               3
      1               3               3
      What can i do for this error?
      Thank you
      Is the Velocity Step Applied or Ramped?
      Using Ramped should avoid this error.
      Read this Discussion.
    • kdh195
      It's Ramped sir.
      Thank you for Discussion Link
      Don't worry about why it is different, just know that changing the Initial, Minimum and Maximum Time Step parameters can help a model move from Error to No Error.
  • The topic ‘Rotational Velocity in Rigid Dynamics’ is closed to new replies.
