July 9, 2020 at 11:12 pm
Abdulelah
SubscriberHey, I'm new to Ansys and from what I read on the web I figured that Ansys is using Timoshenko beam theory. I have analytical solution using Euler–Bernoulli beam theory and I would like to compare it with my result from Ansys. So my question is: Does Ansys support Euler–Bernoulli beam theory? If yes how to do it?Â
July 10, 2020 at 12:54 pm
July 10, 2020 at 5:41 pm
Abdulelah
SubscriberThanks for the reply. I have been trying to change the element type to beam4 but without success and I'm still confused with using command snippet. Here is what I'm doing:Â
When I run it I got this error:Â Real constant set 2 undefined but referenced by element 2049.
and when I add r,2,1 and run it I got zero frequencies.Â
July 10, 2020 at 6:22 pm
peteroznewman
SubscriberDid the Solution Output show that Beam4 was the element type being used?
You can get zero frequencies in a modal if you have not constrained the model adequately. As a check, suppress the Solid body and apply a fixed support at one vertex of the line body.
July 10, 2020 at 6:30 pm
Abdulelah
SubscriberYeah it did. I think my problem is with assigning real constants properly. does Ansys take the data from the geometry when I change the element type or should I assign them?Â
July 10, 2020 at 6:34 pm
July 10, 2020 at 7:59 pm
Abdulelah
SubscriberIt worked. Thank you very much!
July 10, 2020 at 8:22 pm
peteroznewman
SubscriberPlease reply with the text you put in the Command Object to help others who might want to do this.
July 10, 2020 at 9:15 pm
Abdulelah
Subscribersure, below "et,matid,beam4" I wrote the following:Â
r,2,0.0016,2.1333e-7,2.1333e-7,0.04,0.04,0,0,0Â
Where 0.0016 is the area, 2.1333e-7 is IZZ, etc.Â
March 16, 2021 at 7:52 am
ciema
SubscriberDear Peter, maybe you know if there is possibility to display stresses in beam4 when user-defined cross section was used via Command Object (as in the example above)? I have searched, but cant find clear information if stresses are not available. I found only on one of the forum:nIt is about numerical integration and some finite element method basics.nWhen you define cross section by moment of intertia etc., you don'tndefine integration points in your section, you don't define the shape ofnyour cross-section at all. That's why you don't have stressess.nIn this case your will get always approximate results (for examplendeflection).nn[...] it is impossible to improve this thing. That'snthe way it is calculated in case of sections defined by moment ofnintertia etc. and it is ok.nnI activated Beam Section Results option in Solution, but it does not help.nnMaybe there is another - current technology element which can help to use Timoshenko Theorem and can help display the values of stresses? Or its totally impossible?nThanks in advance for the reply..n -
March 16, 2021 at 12:37 pm
peteroznewman
Subscribern/forum/discussion/25701/cannot-plot-stress-results-for-beam4-element#latestn
- The topic ‘Euler–Bernoulli beam theory’ is closed to new replies.
6219
