June 4, 2026 at 12:14 am
kamilayu
SubscriberHello,
I am using ANSYS Rocky 2026 R1 Student coupled with Fluent 2026 R1 Student for a CFD-DEM simulation.
Model Information
CFD mesh: approximately 62,500 cells
Geometry size: 200 × 200 × 100 µm
Approximately 75 particles generated successfully in Rocky
Two-way Fluent coupling enabled
Problem Description
The coupled simulation does not proceed correctly after initialization.
Rocky generates the particle bed successfully and Fluent launches. The coupling process begins, but Fluent reports the following messages:
Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed.and
Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: #fRocky Messages
Rocky also reports:
averaging warning: target volume fraction of 0.48 not reached after 1000 iterations limitHowever, particles are successfully created and visible in the domain, so I am not sure whether this warning is related to the main failure.
Observations
Rocky starts normally.
Particle generation completes.
CFD mesh is exported.
Fluent and Rocky establish communication.
Fluent then reports the journal-file error shown above.
The simulation does not advance as expected after this point.
Questions
Does the Fluent error
Error: CAR: invalid argument [1]: wrong type [not a pair]indicate a corrupted journal file or coupling script?
Could Rocky-Fluent coupling generate an invalid Fluent command during initialization?
Is this a known issue in Rocky 2026 R1 Student / Fluent 2026 R1 Student?
Which log files should I inspect to identify the command that caused the journal-file failure?
- The setup is being operated from workbench
Any guidance would be greatly appreciated.Thank you.
June 5, 2026 at 12:45 pm
Lucas Hoenicke
SubscriberHello,
To successfully performe a coupled rocky-fluent simulation, you must pay attention to the limitations , please check.
Also, read the tutorials: Chapter 14: Tutorial – Fluidized Bed
Chapter 16: Tutorial – Mixing Tank
They will help you understand how it works practically.Please, see if this helps or not. If it doesn't, then please report back here (in the same thread).
6625
1311
