Error during close session of Fluent
    • ecrod
      Hello All,
      Every time I try to close Fluent session I receive this message : Posting ANSYS Product Improvement Program performance data
      Done.
      And after two minutes:
      0: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      2: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      3: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      4: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      5: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      6: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      7: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      8: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      9: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      10: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      11: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      12: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      13: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
      MPI Application rank 0 exited before MPI_Finalize() with status 0
      The fl process could not be started.
      I am running in parallel with 14 cores. What could be a cause for this error message ?
      Thanks in advance.
    • Rahul Kumar
      Which version of Fluent are you using?
    • ecrod
      I have been using version 2019 R2 academic.
    • Rahul Kumar
      Do you get any error while running in serial?
    • ecrod
      I got this error in serial:
      Done.
      It have been happening only when I try to close session. During calculation everything is ok.
    • Rahul Kumar
      Is this with just one particular simulation or does this error occur with any simulation model? Also, can you please update to Ansys 2020 R1 and try again?
    • ecrod
      I was used to wok in version 2019 R2 without MPI installed. And the display interface was look like that :
    • Amine Ben Hadj Ali
      Both pictures correspond to different version. Clean uninstall and install as root. Check installation log files.
    • ecrod
      Abenhadj,
      I did not understand. Both pictures shows 2019 R2 and R19.2 versions.
      Why are different ? In this case, which is the version of each ?
      Thanks.
    • Rahul Kumar
      Yes, both are 2019 R2, the first picture is when you open Fluent through workbench and the next one is a standalone version. What Amine is suggesting is to uninstall Ansys from the start menu and also delete any related folders or files (not the simulations) and install again (make sure you choose "run as administrator".
    • ecrod
      I believe that the problem was solved after install updates in my Windows.
      I am not receiving this messages anymore when Fluent session is closed.
      Thanks
    • Rahul Kumar
      Awesome! Please mark "Is Solution" so that other members in the community can be benefited.
Viewing 11 reply threads
  • The topic ‘Error during close session of Fluent’ is closed to new replies.
