LS Dyna
LS Dyna
The damage evolution law in the Holmquist-Johnson-Cook (HJC) model
    • hscj
      Hello everyone, I am a current master's student. I am currently attempting to develop the secondary application of the HJC constitutive model. The single-unit test has been successfully completed so far. However, in the model where the quality block impacts the thin plate, the damage and stress-strain updates of the custom HJC constitutive model are different from the evolution of the built-in HJC constitutive model of LS-DYNA. I have consulted many people and AI, and also reviewed numerous literature. I have found that the main problem might lie in the radial regression algorithm and the code for damage accumulation. Could everyone please help me identify which part of the code has the issue? Thank you very much!
      HJC CODE BEGIN
            subroutine umat41 (cm,eps,sig,epsp,hsv,dt1,capa,etype,tt,
           1 temper,failel,crv,cma)
      c
      c******************************************************************
      c|  HJC Model Implementation with Plastic Volumetric Strain Damage |
      c
            include 'nlqparm'
            include 'iounits.inc'
            common/bk06/idmmy,iaddp,ifil,maxsiz,ncycle,ctime(2,30)
            character*5 etype
            dimension cm(*),eps(*),sig(*),hsv(*)
            logical failel
            real epsp, dt1, capa, tt, temper
      c     Variable definitions
            real G, K_elastic, A, B, C, N, FC, T, EPSILON_RATE, EFMIN, SFMAX
            real PC, UC, UL, PL, D1, D2, K1, K2, K3
            real pre_sij(6), hydro_strain_Inc, eij_Inc(6), tr_sij(6)
            real tr_sij_J2, Q_trial, mu_old, mu_new, mu_max, mu_plastic
            real P_new, P_max, P_old_stress, P_star, T_star, T_current
            real eps_dot_star, strainRate_eq, Yield_star, Yield_HJC
            real eps_p_f, strainOld, Damage, e_vol_inc, d_mu_p
            real smallNum, k_value, true_sij(6), P_sum_check
            real K_unload, F_interp
            real e_plaStrain_Inc, mu_bar, mu_plaStrain
            parameter (zero = 0.0d0, half = 0.5d0, one = 1.0d0,
           1           two = 2.0d0, three = 3.0d0)
            smallNum = 1.0d-20
      c     Get material parameters
            G = cm(1)
            K_elastic = cm(2)
            A = cm(3)
            B = cm(4)
            C = cm(5)
            N = cm(6)
            FC = cm(7)
            T = cm(8)
            EPSILON_RATE = cm(9)
            EFMIN = cm(10)
            SFMAX = cm(11)
            PC = cm(12)
            UC = cm(13)
            PL = cm(14)
            UL = cm(15)
            D1 = cm(16)
            D2 = cm(17)
            K1 = cm(18)
            K2 = cm(19)
            K3 = cm(20)
            if (etype.eq.'solid'.or.etype.eq.'shl_t') then
      c     =====================================================================
      c     Step 1: Extract history variables and preprocessing
            P_old_stress    = hsv(1)
            mu_old          = hsv(3)
            strainOld       = hsv(5)
            Damage          = hsv(14)
            mu_max          = hsv(15)
            P_max           = hsv(16)
            mu_plaStrain    = hsv(2)
      c     Calculate equivalent strain rate
            strainRate_eq = sqrt(two/three * (eps(1)**2 + eps(2)**2 +
           1                eps(3)**2 + half*(eps(4)**2 + eps(5)**2 +
           2                eps(6)**2))) / max(dt1, smallNum)
            eps_dot_star = strainRate_eq / max(EPSILON_RATE, smallNum)
            if (eps_dot_star .lt. one) eps_dot_star = one
      c     Elastic predictor (deviatoric stress)
            pre_sij(1:3) = sig(1:3) + P_old_stress
            pre_sij(4:6) = sig(4:6)
            e_vol_inc = (eps(1) + eps(2) + eps(3)) / three
            eij_Inc(1:3) = eps(1:3) - e_vol_inc
            eij_Inc(4:6) = eps(4:6)
            tr_sij(1:3) = pre_sij(1:3) + two * G * eij_Inc(1:3)
            tr_sij(4:6) = pre_sij(4:6) + G * eij_Inc(4:6)
            tr_sij_J2 = half * (tr_sij(1)**2 + tr_sij(2)**2 + tr_sij(3)**2)
           1          + tr_sij(4)**2 + tr_sij(5)**2 + tr_sij(6)**2
            Q_trial = sqrt(three * tr_sij_J2)
      c     Step 2: Equation of state (EOS) and pressure parameter update
            hydro_strain_Inc = - (eps(1) + eps(2) + eps(3))
            mu_new = mu_old + hydro_strain_Inc
      c     [Improvement] Precompute dynamic unloading and tensile bulk modulus K_unload
      c     Reference: Interpolate between K_elastic and K1 based on compaction level
            if (mu_max .le. UC) then
               K_unload = K_elastic
            else if (mu_max .lt. UL) then
               F_interp = (mu_max - UC) / (UL - UC)
               K_unload = (one - F_interp) * K_elastic + F_interp * K1
            else
               K_unload = K1
            end if
            if (mu_new .ge. mu_max .and. mu_new .gt. zero) then
              ! --- Loading path (skeleton curve) ---
              if (mu_new .le. UC) then
                P_new = K_elastic * mu_new
              else if (mu_new .le. UL) then
                P_new = PC + (mu_new - UC)*(PL - PC)/(UL - UC)
              else
                mu_bar = (mu_new - UL) / (one + UL)
                P_new = PL + K1 * mu_bar + K2 * mu_bar**2 + K3 * mu_bar**3
              end if
              mu_max = mu_new
              P_max  = P_new
            else
              ! --- Unloading and tension ---
              if (mu_new .lt. zero) then
                ! Tension: use degraded unloading modulus according to literature
                P_new = K_unload * mu_new
              else
                ! Compressive unloading: linear return from P_max using dynamic K_unload
                P_new = P_max - K_unload * (mu_max - mu_new)
                if (P_new .lt. zero) P_new = zero
              end if
            end if
      c     Tension cutoff
            T_current = T * (one - Damage)
            if (P_new .lt. -T_current) P_new = -T_current
      c     [Improvement] Calculate plastic volumetric strain increment d_mu_p
      c     Since modulus is dynamic K_unload, the elastic volumetric strain subtraction should also use current modulus
            d_mu_p = zero
            if (mu_new .gt. UC .and. hydro_strain_Inc .gt. zero) then
               d_mu_p = hydro_strain_Inc - (P_new - P_old_stress)/K_unload
               if (d_mu_p .lt. zero) d_mu_p = zero
            end if
            mu_plaStrain = mu_plaStrain + d_mu_p
      c     Update P* and T* immediately (for denominator and HSV6 calculation)
            P_star = P_new / max(FC, smallNum)
            T_star = T / max(FC, smallNum)
      c     Step 3: Damage denominator calculation (NaN protection)
            P_sum_check = P_star + T_star
            if (P_sum_check .le. 1.0d-8) then
              eps_p_f = EFMIN
            else
              eps_p_f = D1 * (P_sum_check)**D2
            end if
            if (eps_p_f .lt. EFMIN) eps_p_f = EFMIN
      c     Step 4: Yield surface and radial return (fix multiplication order of SFMAX and strain rate)
      c     Step 4: Failure fuse (advanced protection)
      c     If damage exceeds 0.999d0, trigger fuse early to avoid numerical noise
            if (Damage .gt. 0.999999d0) then
               Damage = 1.0d0
               Yield_HJC = 0.001d0 * FC   ! residual strength
               e_plaStrain_Inc = zero
               k_value = Yield_HJC / max(Q_trial, smallNum)
               true_sij(1:6) = tr_sij(1:6) * k_value
                goto 999
            endif
      c     Yield surface calculation
               Yield_star = A * (one - Damage) + B * (P_star**N)* (one
           1      + C * log(eps_dot_star))
               if (Yield_star .gt. SFMAX) Yield_star = SFMAX
      c        Add safety cutoff: prevent Yield_star from becoming negative due to numerical fluctuations
               if (Yield_star .lt. zero) Yield_star = zero
            Yield_HJC = Yield_star * FC
            if (Q_trial .gt. Yield_HJC) then
              e_plaStrain_Inc = (Q_trial - Yield_HJC) / (three * G)
              strainOld = strainOld + e_plaStrain_Inc
            else
            end if
      c     Step 5: Damage accumulation (numerical tolerance completion)
      c     Only accumulate if damage has not reached the set 'quasi-failure threshold'
            if (Damage .lt. 0.999999d0) then
                  Damage = Damage + (e_plaStrain_Inc + d_mu_p) / eps_p_f
            end if
      c     [Core modification]: Force numerical closure
      c     Once damage exceeds the threshold of 0.999999, directly set to 1.0
      c     This solves the precision error concern and ensures complete red in contour
            if (Damage .ge. 0.999999d0) Damage = one
      c     Step 6: Update history variables (meeting user requirements: hsv2, hsv6)
      999   continue
            sig(1:3) = true_sij(1:3) - P_new
            sig(4:6) = true_sij(4:6)
            hsv(1)  = P_new
            hsv(2)  = mu_plaStrain
            hsv(3)  = mu_new
            hsv(4)  = e_plaStrain_Inc
            hsv(5)  = strainOld
            hsv(6)  = D1 * (P_sum_check)**D2
            hsv(7:12) = eps(1:6)
            hsv(13) = eps_dot_star
            hsv(14) = Damage
            hsv(15) = mu_max
            hsv(16) = P_max
            epsp    = strainOld
            end if
            return
            end
      HJC CODE END
      LS-DYNA-HJC
      UMAT-HJC
    • hscj
      My email address is hscj@mail.ustc.edu.cn. If you are interested in the second-level development, please feel free to contact me. I am also planning to explore new technologies such as near-field dynamics and neural network rendering!
    • ErKo
      Hi
      Troubleshooting and reviewing user defined material is outside what Ansys employees can help with. Please wait for other forum members that have experience with umats and user defined material to chime in and perhaps provide feedback. Thank you
      Erko
      • hscj
        Hi
        Thank you for your reply. I am currently continuing to investigate the causes of the abnormal evolution of the damage. Thank you very much.
        CJ
        • ErKo
          Hi
          As we said troubleshooting and reviewing user defined material is outside what Ansys employees can help with.
          Be patient and wait for other forum members (non Ansys empl.) that have experience with umats and user defined material to chime in perhaps and provide feedback. Thank you
          Erko
