LS Dyna
LS Dyna
The reaction at the points I need isn’t displayed in LS-Dyna Workbench.
    • javat33489
      Hello everyone, I have a model made of beams, it's a steel frame. I selected the required points in the FORCE REACTION tracker. But when I run the calculation, I see the following warnings:
      *** Warning 50135 (MPP+135)
      Tracked node is not constrained
      since it is not found on a segment.
      tied interface # = 725
      tracked node # = 86264
      And there are no results. Why?
Viewing 0 reply threads
