February 14, 2026 at 7:41 am
scabo
SubscriberHi-
There are a lot of options to choose from in the numerics tab like accuracy control, trajectory integraion scheme, node based averaging, dynamic interaction range, etc. How to choose the best or most optimum settings for my problem. I am simulating micrometer sized particles in water in a pipe. For the first case, I have read the user guide and applied the following settings; switched off the accuracy control, set RK as integration scheme, switched on node based averaging and dynamic interaction. Do these settings affect the particle results heavily?? Some clarity is needed regarding choosing these settings. thanks.
Viewing 0 reply threads
1831
1387
1248
