February 12, 2026 at 9:19 pm
sash
SubscriberI have a material in 2D Maxwell AC Conduction that has a nonlinear conductivity set as in the figure below.
When I simulate, the E-field or voltage is not solved in this material, even though I check the box on the material to solve inside. I also set the insulator and conductor levels to 0 S for insulator and very high value for conductor. What else can I do to fix this?
February 17, 2026 at 10:30 pm
MirandaH
Ansys EmployeeHi, do you have excitation assigned on those two boxes?
1836
1387
1248
