CFD Post slow animation rendering
    • Daniel.dejan.gunde
      I'm using CFD Post for animation rendering. The rendering is very slow, almost 2 minutes per frame. It's a fairly simple 2D model where both css and cdat files are below 30MB but there is a lot of files in one directory - almost 30.000. Only opening a complete case takes probably hours. I don't know how much exact as I'm always working on something else during loading. It feels like it goes faster if I separate the case into several directories but means additional work. Are familiar with this behavior and is it possible to do something about it?
      Daniel
    • Essence
      Did you try to post-process the results in some other directory or folder? Do you have any background application(s) running simultaneously?
      Normally I need to run simulations simultaneously. Of course I accept some drop of performance but it does feel excessive. I noticed that the rendering can go faster if a folder contains much fewer result files, but that also introduces more work eg. dividing the whole batch of results and putting together pieces of animations at the end.
    • Essence
      I see. In that case, please ensure you have adequate memory resources. Also check the quality of the frames/video getting generated. Higher quality will demand more resources.
